Hello Chris,
Referring to Mantis 259:
The first question to ask is what might be different between this and a more
conventional PPC. Is it a site specific vxWorks BSP?
It says "Exception current instruction address". Do we know what type of
exception it is (this presumably can be decoded from the machine status
register value)? Could it be a floating point exception? Are the floating
point registers saved by ISR that use floating point?
Does this happen only if CA clients are connected?
You might also try the following:
O Use the "i" command to see if any of the TCBs (task control blocks) are
corrupted and or if any other threads are suspended (in a failed state).
O Use the memShow command to detect corrupted pool.
Jeff
__________________________________________________________
Jeffrey O. Hill Mail [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA Fax 505 665 5107
Acces I/O 104-AIO16-16E A/D Card Jon Brinkmann
Re: Building a standalone IOC for an Intel embedded system David Kline
<2006>
2025
2026
about building ChannelArchiver for base3.14 Zhao Zhuo
<2006>
2025
2026
