On May 31, 2006, at 4:27 AM, Dirk Zimoch wrote: Hi all,
attached is a test program that can reproduce the problem. Since it uses sysClkRateGet(), it compiles only on vxWorks.
It calls pasynOctet->readRaw() once with pasynUser->timeout=1.1/sysClkRateGet() and once with pasynUser->timeout=1.0/sysClkRateGet().
In the first case, readRaw() returns asynTimeout, as expected. In the second case, readRaw() does not return.
I print the thread ID before calling readRaw(). When I do 'tt' on the thread ID, readRaw() suddenly returns asynTimeout. Very strange.
Hmm.... This sounds like a task starvation issue. It appears that the read task is looping at a higher priority than the event timer callback task and so is preventing the callback from running. My suspicion is that it's the vxWorks version of select() which is not rounding the timeout up to at least one tick. If so, the problem will still be present in the latest version of ASYN.
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
- Re: asynDriver / epicsTimer bug Dirk Zimoch
- asynDriver / epicsTimer bug Dirk Zimoch
Re: asynDriver / epicsTimer bug Eric Norum
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
