1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor.h file broken for C
To: Doug Murray <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 02 Jun 2006 16:21:15 -0500
Hello Doug,
What compiler are you using?
I compiled the latest distribution of the motor record (R5-9) using
five different compilers without a problem.
I presume you mean these C++ comments in motor.h;
"LSB_First (TRUE) // LSB is packed first."
I have changed these to C comments and committed the changes
into CVS. They will appear in the next release.
Could you be more specific as to the "missing typedef" problem?
I don't see that.
Best regards,
Ron
Doug Murray wrote:
Hi Ron, the motor.h include file (we’re using 3.14.8.2) seems to be written for inclusion in C++ files. Specifically, there are a couple of ‘//’ comments and a missing typedef for an enum. Can you change this file to accommodate both C and C++?
-doug
Doug Murray
Stanford Linear Accelerator Center
LCLS Controls Department
2575 Sand Hill Road
Menlo Park, CA 94025 MS-102
Re: Motor.h file broken for C Doug Murray
Prev: Keithley 6485, was: Re: need help Maren Purves
Next: Solution to install MCA on Windows Gan Quan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Motor.h file broken for C Doug Murray
Next: Re: Motor.h file broken for C Doug Murray
