1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Solution to install MCA on Windows
To: [email protected]
Date: Sat, 3 Jun 2006 16:52:32 +0800
The cause of error LNK2001 is that MCA cannot find ca.lib and Com.lib.
"cd" to the MCA root directory and run:
mex -ID:\Tools\Epics\base-3.14.7\include -ID:\Tools\Epics\base-3.14.7
\include\os\WIN32 -v  mca.cpp MCAError.cpp Channel.cpp ChannelAccess.cpp
dbStaticHost.lib ca.lib Com.lib
If you use MSVC to compile, you may find:
mca.cpp(588) : error C2065: 'min' : undeclared identifier
Then,you need to modify mca.cpp and add a line:
#define min(a, b) (((a) < (b)) ? (a) : (b))
Recompile, you will succeed.
Re: Solution to install MCA on Windows Steven Banks
Prev: Re: Motor.h file broken for C Ronald L. Sluiter
Next: Re: Solution to install MCA on Windows Steven Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor.h file broken for C Doug Murray
