Here is a cut-and-paste from our Matlab Installation Procedure for Windows
at the Australian Synchrotron:
1. Copy the file mca.tar.gz to the <matlab>\toolbox directory, where
<matlab> is the root directory when MATLAB was installed.
2. Unzip the file using Winzip. This should create a directory named
<matlab>\toolbox\mca.
3. In the mca directory, edit the file mcacompile.m and modify it so that
it contains the following:
cd <matlab>\toolbox\mca
mex mca.cpp C:\epics\base\lib\win32-x86\Com.lib ...
C:\epics\base\lib\win32-x86\ca.lib ...
-DDB_TEXT_GLBLSOURCE -D_WIN32 -DEPICS_DLL_NO ...
-IC:\epics\base\include ...
-IC:\epics\base\include\os\WIN32 ...
-v
4. Start MATLAB by double clicking on the MATLAB desktop icon.
5. Add the directory <matlab>\toolbox\mca to the MATLAB search path by
selecting File->Set Path. Click on the ?Add with Subfolders? button and
select the folder <matlab>\toolbox\mca. Press the Save button and then
the Close button.
6. In the MATLAB command window, type the following command:
>> mex -setup
Respond ?y? to let MATLAB search for installed compilers, select the
option to use the MS Visual C/C++ Version 6.0 compiler and type ?y? to
confirm that this is correct.
7. In the MATLAB command window, type the following command:
>> mcacompile
This will create the file mca.dll.
Hope this helps.
Dr. Steven M. Banks ? Control Systems Engineer
Australian Synchrotron Project
Major Projects Victoria
800 Blackburn Road
CLAYTON VIC 3168
tel: +613 8540 4103
fax: +613 8540 4200
mailto:[email protected]
http://www.synchrotron.vic.gov.au
-----Original Message-----
To: [email protected]
Date: Sat, 3 Jun 2006 16:52:32 +0800
Subject: Solution to install MCA on Windows
> The cause of error LNK2001 is that MCA cannot find ca.lib and Com.lib.
> "cd" to the MCA root directory and run:
> mex -ID:\Tools\Epics\base-3.14.7\include -ID:\Tools\Epics\base-3.14.7
> \include\os\WIN32 -v mca.cpp MCAError.cpp Channel.cpp
> ChannelAccess.cpp
> dbStaticHost.lib ca.lib Com.lib
> If you use MSVC to compile, you may find:
> mca.cpp(588) : error C2065: 'min' : undeclared identifier
> Then,you need to modify mca.cpp and add a line:
> #define min(a, b) (((a) < (b)) ? (a) : (b))
> Recompile, you will succeed.
- Thanks for help Gan Quan
- Solution to install MCA on Windows Gan Quan
<2006>
2025
2026
<2006>
2025
2026
