1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA troubles
To: [email protected]
Date: Tue, 20 Jun 2006 08:16:50 +0200
Hello,
I have some problems with Channel Access to get data from an ioc running on redhat9 kernel 2.4.20-8smp with epics version3.14.7.
On the ioc shell side, I have the following message :
CAS: request from 192.168.101.20:50482 => "bad resource ID"
CAS: Request from 192.168.101.20:50482 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0
CAS: Request from 192.168.101.20:50482 => available=0x1 N=0 paddr=(nil)
CAS: forcing disconnect from 192.168.101.20:50482
CAS: request from 192.168.101.20:50539 => "bad resource ID"
CAS: Request from 192.168.101.20:50539 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0
CAS: Request from 192.168.101.20:50539 => available=0x1 N=0 paddr=(nil)
CAS: forcing disconnect from 192.168.101.20:50539
Has someone ever met such a problem ?
Thanks
Christophe
RE: CA troubles Jeff Hill
Prev: Updated modules Eric Norum
Next: Eclipse reading list Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CA troubles Jeff Hill
