1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA troubles
To: "'Christophe Moins'" <[email protected]>, <[email protected]>
Date: Wed, 21 Jun 2006 10:38:00 -0600
Hello Christophe,
What architecture do the client and server run on? Are both the client and
server running EPICS R3.14.7?
Jeff
> -----Original Message-----
> From: Christophe Moins [mailto:[email protected]]
> Sent: Tuesday, June 20, 2006 12:17 AM
> To: [email protected]
> Subject: CA troubles
> Hello,
> I have some problems with Channel Access to get data from an ioc running
> on redhat9 kernel 2.4.20-8smp with epics version3.14.7.
> On the ioc shell side, I have the following message :
>  CAS: request from 192.168.101.20:50482 => "bad resource ID"
> CAS: Request from 192.168.101.20:50482 => cmmd=12 cid=0xffffffff type=0
> count=0 postsize=0
> CAS: Request from 192.168.101.20:50482 =>  available=0x1        N=0
> paddr=(nil)
> CAS: forcing disconnect from 192.168.101.20:50482
> CAS: request from 192.168.101.20:50539 => "bad resource ID"
> CAS: Request from 192.168.101.20:50539 => cmmd=12 cid=0xffffffff type=0
> count=0 postsize=0
> CAS: Request from 192.168.101.20:50539 =>  available=0x1        N=0
> paddr=(nil)
> CAS: forcing disconnect from 192.168.101.20:50539
> Has someone ever met such a problem ?
> Thanks
> Christophe
CA troubles Christophe Moins
Prev: VDCT survey results Shepherd, EL (Emma)
Next: Question on supporting GPIB waveform acquisition from a variety of scopes Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA troubles Christophe Moins
Next: Eclipse reading list Andrew Johnson
