Title: Message
Steven,
I was curious why the GW code might be crashing
when it was unable to create a thread. The code should of course just refuse to
attach to another client if it runs low on resources.
I looked in CVS and it appears that there
is a patch to the posix version of the epicsThreadCreate function, first
appearing in R3.14.7, which changes a checkStatusQuit macro invocation to a
checkStatus macro invocation. The net impact is that, in R3.14.6, if there is
any problem creating a thread in the posix version of epicsThreadCreate the
thread is suspended inside of epicsThreadCreate, but this is fixed in R3.14.7.
Jeff
We are having severe problems with the EPICS gateway, and
I'm hoping that someone can help us resolve them.
The problem is that the gateway is continually crashing
whenever we open up a GUI display with requires connection to multiple
IOCs. These are Libera BPM boxes, and we have 98 of them. We have a
status display which shows the status of 33 of these at once. As we
scroll from one display to the other, the gateway invariably crashes.
(This is a gateway between our office network
and our accelerator network, and is used for monitoring the status of the
machine from our desktops.)
The gateway log provides the following information:
Jun 26 16:01:02 PV Gateway Version 2.0.0.0 [Jun 14 2006
15:10:22]
EPICS 3.14.6 PID=8840 ServerPID=8839
EPICS_CA_ADDR_LIST=BROADCAST-ACC
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=CR01GW01-OFFICE
EPICS_CAS_SERVER_PORT=Not specified
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Running as user ics on host CR01GW01
Statistics PV prefix is CR01GW01
pthread_create error Cannot allocate memory
Jun 26 16:36:12 !!! Errlog message received (message is
above)
fatal error: epicsThreadCreate
above)
Has anyone else seen the memory problems that we are
experiencing? Is this an indication that we are trying to connect to too
many PVs at once? Will purchasing more memory for the gateway perhaps
alleviate the problem. It currently has 512MB but we are planning to
upgrade it to 1 GB.
- Gateway Crashes Steven Banks
Re: problem about compiling EPICS base on Int el XScale RISC CPU and Monta Vista Linux Michael Abbott
RE: Gateway Crashes Russ Berg
<2006>
2025
2026
Re: Gateway Crashes Dirk Zimoch
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
