1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev lib off-board register access
To: "Rees, NP (Nick)" <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jul 2006 11:44:43 -0500
Rees, NP (Nick) wrote:
This is really a follow-up to the 2002 thread on PowerPC caching:
http://www.aps.anl.gov/epics/tech-talk/2002/msg00417.php
That thread ended up talking about write posting through the VME bridge, I'm not sure whether it's the same thing you're talking about or not.
At Diamond we use the mvme5500. It seems that every vxWorks driver we
have will fall over at some point unless we are careful with memory
caching. Very few EPICS drivers do this properly. However, on the
mvme5500 if we precede every read with a cacheInvalidate and follow
every write routine with a cacheFlush we don't seem to have any
problems.
Caching should only be an issue if you have two bus masters accessing the same area of memory; i.e. if there is a DMA controller or a second CPU involved in the I/O operation. Not many EPICS drivers actually use a DMA controller, so most drivers don't need to worry about cache coherency issues.
There is an option in Marty Kraimer's Generic Transient Recorder support to make use of some BSP-supplied DMA routines that I wrote for the Universe-2 and VMEchip2 bridges. My implementation of this VME DMA support *should* perform the necessary cache manipulation operations at the appropriate time (the requirements are different on different boards though; most boards can do bus snooping, but some do not and require the driver to call cacheInvalidate() before reading and cacheFlush() after writing the shared area).
Later, Rees, NP (Nick) wrote:
Peter Denison gave me the following link to the Linux kernel sources
which gives a reasonable description of sync, lwsync, eieio and wmb, rmb
etc.
http://lxr.linux.no/source/include/asm-ppc64/system.h#L18
I assume that at the bottom of cacheFlush and cacheInvalidate is a sync
instruction on the PPC, but I might be wrong. I certainly don't see it.
Not necessarily, since sync is an expensive instruction on the PowerPC which you would really rather not execute if you can avoid it. A cacheFlush() will perform other instructions that ensure the cache area specified is definitely pushed out to memory before it returns, but that doesn't necessarily need a sync.
Note that all the VMEbus windows should be marked as Non-Cacheable and Guarded in your BSP's sysPhysMemDesc[] table.
The problem we have found with the 5500 is, I think, related to the
problem outlined in the 2002 tech-talk thread. The processor MMU may
know the VME memory isn't cached, but there is also a cache in the VME
chip (why, I don't know) and that has to be forced as well.
Ok, that's a different issue and not a cache; the Universe-2 VME bridge chip has a write pipeline which enables a PCI bus write cycle to complete before the matching VMEbus cycle does. Cycles on VMEbus are generally much slower than on the PCIbus, and there's no reason to hold up the processor just to wait for the cycle to complete, so the bridge chip has a write FIFO built into it that allows it to queue up a series of write operations. This speeds up the processor operation quite a bit, at the expense of having to be a little more careful in the software (and a loss of synchronization with VME Bus errors, but that's a slightly different topic).
The bridge ensures that all pending VME write operations are performed before it will execute any subsequent VMEbus read, for which it has to delay the PCIbus cycle since it can't complete that without getting the read data from the VME cycle anyway. This ensures that the I/O cycles are still performed in the same order that the CPU requested them, but the timing may be different.
Usually the different timing that doesn't matter, but there is one circumstance where it does - clearing interrupt requests from VME boards. Here an Interrupt Service Routine needs to ensure that any write cycle going to a VME slave board that causes it to deassert an IRQ line gets out to the board before we return from the ISR, otherwise nasty things happen. The way to guarantee this is to perform a dummy read from some register on the VME board at the end of the ISR, which pushes the VMEbus writes out and thus clears the IRQ condition.
This should be sufficient to fix your problem; the cacheFlush and/or cacheInvalidate that you were calling were inserting a delay into the CPU instruction chain which was probably sufficient time for the VME write pipeline to flush itself naturally. Howere this is not guaranteed, so I suggest you fix these with the VME read instead.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
RE: Dev lib off-board register access Thompson, David H.
Dev lib off-board register access Rees, NP (Nick)
Prev: Re: Dev lib off-board register access Eric Bjorklund
Next: Waveform record help Erik Johansson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Dev lib off-board register access Andrew Johnson
Next: RE: Dev lib off-board register access Thompson, David H.
