1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev lib off-board register access
To: "Rees, NP (Nick)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 14 Jul 2006 12:08:19 -0500
Rees, NP (Nick) wrote:
One of our problems is that on one of the boards the interrupt acknowledge register is write only - so a read from it generates a bus error, which isn't as pretty as it should be. I presume (from Andrews email) that if we read a value from any other readable VME memory location, that will flush the pipeline just as well. Is that correct?
Yup, that's what the book says and my experience has confirmed that. You might want to check that all your VMEbus master windows are marked as Guarded in the sysPhysMemDesc[] table too, since that's the mechanism by which the CPU is told it can't reorder read and write I/O operations within this memory range.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
RE: Dev lib off-board register access Rees, NP (Nick)
Prev: Re: Dev lib off-board register access Andrew Johnson
Next: Re: Dev lib off-board register access Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Dev lib off-board register access Rees, NP (Nick)
