Jukka Pietarinen wrote:
I believe it has to be the same register the write was targeted at. I
It shouldn't be - the Universe-2 User Manual says explicitly in section
2.3.3.4: "Any PCI master attempting coupled transactions is retried
while the TXFIFO contains data." A read is always a coupled
transaction, thus any CPU read from the VMEbus should cause a delay
while the TXFIFO is drained. I conclude that your problem is most
likely not caused by the Universe-2 chip itself.
And this is what I see on the bus, which is really not what I wanted:
Read from pEr->Control
Read from pEr->RamData
Write to pEr->Control
Write to pEr->RamAddr
Is your A16 master window marked as Guarded in the sysPhysMemDesc[]
table (in sysLib.c)? I can't think of any other explanation for the
behaviour you were seeing.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- Dev lib off-board register access Rees, NP (Nick)
- Re: Dev lib off-board register access Dirk Zimoch
- Re: Dev lib off-board register access Eric Bjorklund
- Re: Dev lib off-board register access Kate Feng
- Re: Dev lib off-board register access Jukka Pietarinen
RE: Dev lib off-board register access Rees, NP (Nick)
Re: Dev lib off-board register access Andrew Johnson
<2006>
2025
2026
<2006>
2025
2026
