1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Dev lib off-board register access
To: "Kate Feng" <[email protected]>, "Eric Bjorklund" <[email protected]>
Cc: "EPICS tech-talk" <[email protected]>
Date: Fri, 14 Jul 2006 17:36:03 +0100
Thanks everyone for an interesting thread. I think I understand the
issues much better now.
I think the answer to Kate's question is that the dummy read is required
for all VME boards that have pipelines in their VME interface. i.e. it
is not strictly a PPC or mvme5500 issue, but only really surfaces on PPC
boards since they have VME controllers like this.
One of our problems is that on one of the boards the interrupt
acknowledge register is write only - so a read from it generates a bus
error, which isn't as pretty as it should be. I presume (from Andrews
email) that if we read a value from any other readable VME memory
location, that will flush the pipeline just as well. Is that correct?
I also feel that something in devLib that helps with register access and
deals with pipelining, caching and byte swapping issues may help make
code more portable.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Re: Dev lib off-board register access Andrew Johnson
Re: Dev lib off-board register access Kate Feng
Prev: Re: Dev lib off-board register access Jukka Pietarinen
Next: Re: Dev lib off-board register access Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Dev lib off-board register access Andrew Johnson
