1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev lib off-board register access
Cc: Eric Bjorklund <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 14 Jul 2006 14:42:19 -0500
I wrote:
There are boards available now that have 2GB of RAM, meaning that the RAM extends from 0x00000000 to 0x3fffffff which is a quarter of the 32-bit address space.
As Eric kindly pointed out to me, my math is out by a factor of 2 - 2GB of RAM would extend from 0x00000000 to 0x7fffffff. This merely makes my case for a devLib A32 malloc() API even more urgent...
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
Dev lib off-board register access Rees, NP (Nick)
Re: Dev lib off-board register access Dirk Zimoch
Re: Dev lib off-board register access Eric Bjorklund
Re: Dev lib off-board register access Kate Feng
Re: Dev lib off-board register access Andrew Johnson
Prev: Re: Dev lib off-board register access Kate Feng
Next: Can I use the DISA field for user data? Harley N
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Dev lib off-board register access Andrew Johnson
Next: RE: Dev lib off-board register access Rees, NP (Nick)
