1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev lib off-board register access
To: Eric Bjorklund <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 14 Jul 2006 19:23:27 +0300
Hi Eric,
Eric Bjorklund wrote:
On Jul 14, 2006, at 7:45 AM, Kate Feng wrote:
Do you mean the dummy read following the last write is needed for
only vxWorks-mvme5500 ? Or  is it  needed for almost all the powrPC
boards using  VxWorks ? Does it apply to all the VME boards ?
This is pretty much the case for any PPC using the Universe or Tempe VME bridge. But my statement wasn't quite complete. As Andrew pointed out, write posting ("pipeline") is mostly a problem with ISR's issuing a write to clear the IRQ line and the write not actually happening until after the ISR returns (as Andrew also pointed out, the dummy read does not really have to be to the same register). So if your VME board doesn't interrupt, you probably don't need to worry about it.
I believe it has to be the same register the write was targeted at. I had problems accessing indirect RAM (sequence RAM of EVG) with MVME5500 running vxWorks. I first thought it was a compiler optimization problem but the assembler listing was OK. I had to set up a VME bus analyzer to see what was happening on the bus. My test code looks following:
STATUS ReadTest(MrfEvrStruct *pEvr, int ram)
  volatile MrfEvrStruct *pEr = pEvr;
  int address;
  int control;
  int data[4];
  /* Enable Ram for access */
  control = pEr->Control & ~(EVR_C_VMERS | EVR_C_RSTS | EVR_C_HRTBT |
                             EVR_C_IRQFL | EVR_C_LTS | EVR_C_NFRAM |
                             EVR_C_RSADR | EVR_C_RSFIFO | EVR_C_FF |
                             EVR_C_FNE | EVR_C_RSDLIRQ | EVR_C_RXVIO);
  if (ram == 2)
    control |= EVR_C_VMERS;
pEr->Control = control;
  for (address = 0; address < 4; address++)
      pEr->RamAddr = address;
      data[address] = pEr->RamData;
In this code pEr->RamAddr and pEr->RamData are two consecutive two byte
words in VME A16 memory space and the contents of pEr->RamData depend on
the contents of pEr->RamAddr.
And this is what I see on the bus, which is really not what I wanted:
Read from pEr->Control
Read from pEr->RamData
Write to pEr->Control
Write to pEr->RamAddr
The only solution I found was to read back the address every time before reading the data.
Jukka
Re: Dev lib off-board register access Andrew Johnson
Dev lib off-board register access Rees, NP (Nick)
Re: Dev lib off-board register access Dirk Zimoch
Re: Dev lib off-board register access Eric Bjorklund
Re: Dev lib off-board register access Kate Feng
Prev: Re: Dev lib off-board register access Eric Bjorklund
Next: RE: Dev lib off-board register access Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Dev lib off-board register access Andrew Johnson
