A dummy read following the last write is needed for Interrupt Service Routines running on most CPU boards nowadays, and certainly for any Universe-2 based board. Even the old 68K boards using the VMEchip2 can have Write Posting enabled on their VME master windows, although I don't think the write pipeline is anywhere near as long in that case so omitting the read might not cause any noticable effects. A common symptoms of omitting the read is to cause suprious interrupts which will probably have a vector of 0xff. These often appear to be harmless, but they do waste CPU time. Is this implemented in other vxWorks-PPC site such as APS or any other facility ? I did'nt notice this in synApp which was written by APS, but I am off-site now that I can'nt verify the code. It is not really sensible to try and resolve this issue in the BSP, it really should be the VME slave board driver's ISR that generates the dummy read since the BSP is probably not aware of any specific VMEbus addresses that it can read from (and it would not be a good idea to perform an access that generates a Bus Error as this would completely kill interrupt performance). - Andrew -- Not everything that can be counted counts, and not everything that counts can be counted. -- Albert Einstein
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
