1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OPC+EPICS for Linux
To: [email protected]
Date: Sat, 22 Jul 2006 09:21:11 -0700
Dear Tech-talk,
I have a CAEN SY2527 Power supply crate and two A1534 HV modules which need to be controlled by EPICS - Slow Control system for the TOFr.
Looking through the modules section of the EPICS website there appear to be modules for VME based CAEN hardware. Am I correct in assuming this will not help in my case?
The only way possible to control this hardware I believe is via OPC. CAEN supplies a pre-built OPC server for Windows and source code + libraries for Linux.
After having looked through Tech-talk there is an OPC-EPICS interface developed by BESSY - but it is for Windows.
Right now the computer to be connected with the hardware and hence become the IOC server will be a linux machine (presumably Scientific Linux 3.0.5).
My primary question is:
could I use the CAEN supplied source code to write a module which will translate EPICS command to OPC commands and vice versa?
I believe this is very similar to what BESSY has already done, although it would be for Linux.
As I am an EPICS newbie would it be very difficult to write this module within a month, or am I going about this is the completely wrong way?
Bertrand
Re: OPC+EPICS for Linux Andrew Johnson
Prev: How to change medm windows title + windows manager Emmanuel Mayssat
Next: Record fields not accessible in iocsh / database Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to change medm windows title + windows manager Emmanuel Mayssat
Next: Re: OPC+EPICS for Linux Andrew Johnson
