1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to change medm windows title + windows manager
To: epics <[email protected]>
Date: Wed, 09 Aug 2006 17:04:46 -0700
Here is the reply to my own email ;-)
I use devilspie on linux. It works quite well.
To change the windows title of medm windows, you can use xprop
medm -macro "name=TS33" myDisplay.adl
xprop -name "myDisplay" -set WM_NAME "SCREEN_TS16"
xprop -name "myDisplay" -set WM_NAME "SCREEN_TS33"
Once the window title has been changed, devilspie can take over with the
sample configuration file (in ~/.devilspie/sample.ds)
(begin
	(if ( is window_name "SCREEN_TS16" )
		(begin
			(set workspace 2)
			(geometry +100+100)
	(if (is window_name "SCREEN_TS33")
		(begin
			(set workspace 2)
			(geometry +300+100)
This would put the medm screen at the location I want and with the
geometry I want. For your information,
Emmanuel Mayssat
On Fri, 2006-07-21 at 07:43 -0700, Emmanuel Mayssat wrote:
> Hello,
> Is there a way to change the title of an X-window?
> I was also wondering what you are using to set the position of each
> medm/edm windows at login time.
> Thanks for your input.
> Emmanuel
How to change medm windows title + windows manager Emmanuel Mayssat
Prev: Re: Record support for waveout? Steven Hartman
Next: Smooth transition from medm to edm Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How to change medm windows title + windows manager Rowland, J (James)
Next: OPC+EPICS for Linux Bertrand H.J. Biritz
