1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dol->name
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Wed, 26 Jul 2006 09:45:41 -0500
Emmanuel Mayssat wrote:
Hello,
I would like to print the field name that is in the DOL.
What are all the fields for the structure pao->dol?
pao->dol.type --- ok
I could not find this information in the header file.
My understanding is that the epics database DOL are DBF_INLINK.
Where is the associated structure?
See link.h for the different structure definitions. pao->dol is a struct link which is typedef'd to DBLINK. You should check dol.type which for a DOL field at runtime should only ever be CONSTANT, DB_LINK or CA_LINK, and use the appropriate member in the union value to get the field value - you'll only need to use the constantStr or pv_link members. If you want to see some code that does this, look at the function dbGetString() in base/src/dbStatic/dbStaticLib.c.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
dol->name Emmanuel Mayssat
Prev: Re: dol->name Tim Mooney
Next: Allen-Bradley VME Scanner Module 6008 Luchini, Kristi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: communication with rs485 multidrop device and command/response protocol btanu
