1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: looking for OSI version of epid record
To: [email protected]
Date: Thu, 17 Aug 2006 11:36:24 +0200
On Wednesday 16 August 2006 22:22, Mark Rivers wrote:
> Yes, there is a version of EPID which works with EPICS 3.14.x.
> It is included in the "std" module in synApps.
> http://www.aps.anl.gov/aod/bcda/synApps/std/std.html
Just stumbled over a documentation bug in
http://www.aps.anl.gov/aod/bcda/synApps/std/epidRecord.html
Introduction says
>The major improvements in the EPID record compared to the PID record
> include:
> Changed the time units of the KI and KD terms from minutes to seconds
However, Section "Feedback Parameters" says
> Field Summary                                [...]
> KP    Proportional Gain                      [...]
> KI    Integral Gain, in repeats per minute   [...]
> KD    Derivative Gain, in repeats per minute [...]
which leaves me to wonder whether I would have to re-scale KI and KD
when moving from pid to epid or not.
Another question with regard to replacing pid by epid: Apart from teh
above scaling issue, have I understood it correct that if the following
scenario:
a pid record controlling an ao record, the latter in OMSL=closed_loop,
output OIF=incremental mode, DOL referencing pid's DM
would be replaced by
epid record having OUTL point to ao record's VAL, ao record in OIF=full
and OMSL=supervisory mode?
then everything should work the same as before (modulo bugs/unwanted
features)?
Ben
You've never looked into my eyes but don't you want to know
What the dark and the wild and the different know -- Melissa Etheridge
looking for OSI version of epid record Dayle Kotturi
RE: looking for OSI version of epid record Mark Rivers
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Ernest L. Williams Jr.
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: looking for OSI version of epid record Mark Rivers
Next: RE: looking for OSI version of epid record LYNCH, Damien
