1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: looking for OSI version of epid record
To: [email protected]
Date: Fri, 18 Aug 2006 15:55:07 +1000
I am interested in the response to the following question as well (as I have just started using EPID this week myself).
> Another question with regard to replacing pid by epid: Apart from teh
> above scaling issue, have I understood it correct that if the
> following
> scenario:
> a pid record controlling an ao record, the latter in
> OMSL=closed_loop,
> output OIF=incremental mode, DOL referencing pid's DM
> would be replaced by
> epid record having OUTL point to ao record's VAL, ao record
> in OIF=full
> and OMSL=supervisory mode?
I see the EPID record producing a value that should be added to the ao record's VAL field, implying the ao record should have OIF=Incremntal. But with the EPID record putting OVAL into what's pointed to by OUTL (ie the ao record) I'd expect to have
OMSL=supervisory in the ao record.
The way I read the doco I thought EPID would calculate a value that would be put into the ao record (not added to what's already there).
Damien
Re: looking for OSI version of epid record Tim Mooney
Prev: want to run my ioc in Amida Simputer btanu
Next: Re: want to run my ioc in Amida Simputer Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: looking for OSI version of epid record Benjamin Franksen
Next: Re: looking for OSI version of epid record Tim Mooney
