1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: VME Bus Error handling on MVME3100 and 6100 boards
To: [email protected]
Date: Thu, 17 Aug 2006 11:47:52 -0400
Our V124s don't have to be smoked to cause a bus error.
I don't have to be able to debug it to know what is going on.
I do want to know that something happened rather than passing 0xffff up
into the control loop.
========== Response from Motorola below ===============================
Motorola has received the fiollowing response from an engineer that was
involved with the TEMPE and from Tundra:
Tundra states that "the error handling with respect to a BERR
termination as a VMEbus master works as described in the Users Manual.
Tundra has no plans of changing this."  If the customer doesn't feel
that signaling via an interrupt is insufficient then we have no
recourse.  Please note that both Mac and Tundra agree that a failed read
of a valid VME address would likely occur only as a result of a
catastrophic system failure, i.e. the target board smoked.  The
probability that a failed read, when (or if) retried would return data
is essentially zero.
Not sure, what to make out of that initial response?
Prev: RE: VME Bus Error handling on MVME3100 and 6100 boards Thompson, David H.
Next: EPICS Web Mirror How-To Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Next: Porting EPICS to NetBSD David Dudley
