1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Web Mirror How-To
To: EPICS Tech Talk <[email protected]>
Date: Thu, 17 Aug 2006 18:17:57 +0200
Hi All,
To answer some requests I got lately, there's a new How-To in the Wiki area explaining how to set up a local mirror of the EPICS web site.
Please add and correct stuff that is missing or wrong.
Good luck!
Ralph
http://www.aps.anl.gov/epics/wiki/index.php/How_To_Set_Up_a_Mirror_of_the_EPICS_Web_Site
Prev: FW: VME Bus Error handling on MVME3100 and 6100 boards Thompson, David H.
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Original Motorola MVME 167 PROM Jiro Fujita
Next: MVME5500/Kate Feng wrote : > Anyway, the reason why I wanted to > clarify is that there is a cavet about the MVME5500 board, which is > due to its Discovery I system controller. It is a different issue fromwhat was discussed about the dummy read. > * Some PCI devices require Synchronization Barriers or PCI ordering > * for . For example, the VME-OMS58 motor controller we > * used at NSLS requires either enhanced CPU Synchronization Barrier > * or PCI-ordering (only one mechanism is allowed) for the PCI-write. > * The PCI-ordering simply implements a PCI conMVME5500/100 PCI sync. (was Re: Dev lib off-board register access) Kate Feng
