1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Original Motorola MVME 167 PROM
To: "Brad Cumbia" <[email protected]>, "EPICS tech-talk" <[email protected]>
Cc: "Steven Hartman" <[email protected]>
Date: Thu, 17 Aug 2006 15:12:45 -0400
Thank you very much!  I look forward for that (it will probably be
there by the time when I get back to Creighton from BNL).
On 8/17/06, Brad Cumbia <[email protected]> wrote:
They are on their way. You can keep them if you want.
Brad Cumbia
Accelerator Network Administrator/Senior Controls Technologist
Thomas Jefferson National Accelerator Facility
Electrical Engineering Support Group
Instrumentation & Control Systems
Accelerator Computing Environment
12000 Jefferson Avenue
Newport News, Virginia 23606
Phone (757)269-5839
Pager (757)584-5839
Fax (757)269-7309
       ____ __  ___
      / / //  \/ _ \
   __/ / // - / _  /
  /___/___/._/_.__/
||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO|
||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO|
Jiro Fujita wrote:
> As Steven Hartman pointed out, it appears that what I found is a set
> of older VxWorks PROM after all.  Well, it was a thought...
> However, Brad, if you don't mind me borrowing a set of them for a
> while, could you send me a set of 167Bug PROMs??  Here is my address:
> Jiro Fujita
> Department of Chemistry
> Creighton University
> 2500 California Plz
> Omaha,
> NE 68178
> I can try and see what I can do with it.
> I will be visiting Jlab for PCaPAC in October, so unless you need them
> sooner, I should be able to bring them back with me in October.
>> Here is what you need
>> line 1:4379C02B
>> line 2:04/27/94
>> line 3:167 U1 or 167 U2.
>> You need both U1 and U2.
>> I have a bunch of sets.  I can send you a set if you need them.
>> Brad Cumbia
>> Phone (757)269-5839
>> Pager (757)584-5839
>> Fax (757)269-7309
>>        ____ __  ___
>>       / / //  \/ _ \
>>    __/ / // - / _  /
>>   /___/___/._/_.__/
>> Steven Hartman wrote:
>> >>>one, I can't tell if this is it or not.  On the PROM itself, it says
>> >>>"MVME 167 U2 5.02b".  Does anybody have one that you can check with??
>> > If I recall correctly, the U2 chip you have is an old VxWorks PROM
>> > (version 5.02b), not the Motorola one.
RE: Original Motorola MVME 167 PROM Hammonds, John P.
RE: Original Motorola MVME 167 PROM Steven Hartman
Re: Original Motorola MVME 167 PROM Brad Cumbia
Re: Original Motorola MVME 167 PROM Jiro Fujita
Prev: Re: Original Motorola MVME 167 PROM Brad Cumbia
Next: want to run my ioc in Amida Simputer btanu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Web Mirror How-To Ralph Lange
