1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Original Motorola MVME 167 PROM
To: Jiro Fujita <[email protected]>
Cc: EPICS tech-talk <[email protected]>, Steven Hartman <[email protected]>
Date: Thu, 17 Aug 2006 15:09:39 -0400
They are on their way. You can keep them if you want.
Brad Cumbia
Accelerator Network Administrator/Senior Controls Technologist
Thomas Jefferson National Accelerator Facility
Electrical Engineering Support Group
Instrumentation & Control Systems
Accelerator Computing Environment
12000 Jefferson Avenue
Newport News, Virginia 23606
Phone (757)269-5839
Pager (757)584-5839
Fax (757)269-7309
      ____ __  ___
     / / //  \/ _ \
  __/ / // - / _  /
 /___/___/._/_.__/
||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO|
||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO|
Jiro Fujita wrote:
As Steven Hartman pointed out, it appears that what I found is a set
of older VxWorks PROM after all.  Well, it was a thought...
However, Brad, if you don't mind me borrowing a set of them for a
while, could you send me a set of 167Bug PROMs??  Here is my address:
Jiro Fujita
Department of Chemistry
Creighton University
2500 California Plz
Omaha,
NE 68178
I can try and see what I can do with it.
I will be visiting Jlab for PCaPAC in October, so unless you need them
sooner, I should be able to bring them back with me in October.
On 8/17/06, Brad Cumbia <[email protected]> wrote:
Here is what you need
line 1:4379C02B
line 2:04/27/94
line 3:167 U1 or 167 U2.
You need both U1 and U2.
I have a bunch of sets. I can send you a set if you need them.
Brad Cumbia Accelerator Network Administrator/Senior Controls Technologist Thomas Jefferson National Accelerator Facility Electrical Engineering Support Group Instrumentation & Control Systems Accelerator Computing Environment 12000 Jefferson Avenue Newport News, Virginia 23606 Phone (757)269-5839 Pager (757)584-5839 Fax (757)269-7309 ____ __ ___ / / // \/ _ \ __/ / // - / _ / /___/___/._/_.__/ ================================================= () ------------------------------------------------ ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||* * * * * * * * * * :::::::::::::::::::::::::| ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||* * * * * * * * * * :::::::::::::::::::::::::| ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||---------------------------------------------- || || || ||
Steven Hartman wrote:
>>>one, I can't tell if this is it or not.  On the PROM itself, it says
>>>"MVME 167 U2 5.02b".  Does anybody have one that you can check with??
> If I recall correctly, the U2 chip you have is an old VxWorks PROM
> (version 5.02b), not the Motorola one.
Re: Original Motorola MVME 167 PROM Jiro Fujita
RE: Original Motorola MVME 167 PROM Hammonds, John P.
RE: Original Motorola MVME 167 PROM Steven Hartman
Re: Original Motorola MVME 167 PROM Brad Cumbia
Prev: Re: Original Motorola MVME 167 PROM Jiro Fujita
Next: Re: Original Motorola MVME 167 PROM Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
