1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: looking for OSI version of epid record
To: "'Tim Mooney'" <[email protected]>
Cc: [email protected]
Date: Mon, 21 Aug 2006 12:13:31 +1000
Hi Tim,
> > I see the EPID record producing a value that should be
> added to the ao
> > record's VAL field, implying the ao record should have
> OIF=Incremntal.
> > But with the EPID record putting OVAL into what's pointed
> to by OUTL
> > (ie the ao
> > record) I'd expect to have OMSL=supervisory in the ao record.
> Hang in there and see what happens as the controlled value
> responds to the new output value.  With KP!=0 and KI==KD==0,
> you should see ERR=VAL-CVAL, and
> OVAL=KP*ERR.  If not, do a "dbpr" on the record and send
> that.  There might be some control field we're not thinking
> about with an unexpected value.
ERR is calculated correctly and OVAL contains the value == KP * ERR.
But this value now in OVAL is one that I would want to add to the VAL field in the ao record pointed to by OUTL (which in my case writes to a magnet power supply). Is it up then to the database designer to perform an OVAL + ao.VAL calculation and get the
result into ao.VAL?
Damien
Re: looking for OSI version of epid record Andrew Johnson
Prev: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Pete Jemian
Next: Re: looking for OSI version of epid record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: looking for OSI version of epid record Tim Mooney
