1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Any EPICS support for ICS 145?
To: Steve Lewis <[email protected]>
Cc: EPICS tech-talk <[email protected]>, Elden Ables <[email protected]>
Date: Wed, 23 Aug 2006 11:53:07 -0400
On Wed, 2006-08-23 at 08:45 -0700, Steve Lewis wrote:
> Does anyone have experience using (and drivers for) the ICS-145
> 32-channel, 16-bit, 20 MHz digitizer?
Sure.  The SNS actually used the ICS 145 for a beam diagnostics
emittance application.  Carl Lionberger is the original author.
If you want, we can get you a copy from our CVS. :)
> Our engineer particularly
> likes its electrical characteristics, and intends to use the
> companion ICS-141 filter and programmable-gain board.  (Any use of
> this one?)  Note that the combination would limit the bandwidth to
> about 1 MHz.
> This is a change in requirements (fewer channels, higher bandwidth)
> from the original request to tech-talk, to which many of you
> responded with very usable solutions...thanks again.
Any EPICS support for ICS 145? Steve Lewis
Prev: Any EPICS support for ICS 145? Steve Lewis
Next: RE: MAXv Multi-Axis Motion Controller in use? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()" David Dudley
