1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()"
To: <[email protected]>
Date: Wed, 23 Aug 2006 14:15:35 -0500
OK, looks like to a large degree, this is the source of most of the remaining problems on the NetBSD port (at least... most likely culprit).
Looking at the situation, I can see that there's going to be a problem, from using "ioctl(socket, SIOCGIFCONF &ifconf)" inside the code.  On NetBSD, this function returns information that is "inconsistent" with Linux, I believe.
Could someone please give me a rundown on how this function is expected to work?  If it does what I believe it appears to do, I think I can replace it with an equivalent function using "getifaddrs", and possibly make it a little more general at the same time.  I believe all this function is attempting to do is build up a list of interfaces that exist on the machine, that have access to the outside.  If so, I'll code a replacement, and get it functioning.  The problem is, that in NetBSD, ifreq blocks are not necessarily (and probably not) stored in sequential memory blocks, but can/may/are spread across the kernel address space.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" Jeff Hill
Prev: Re: VCCT and CA sniffer Chris Payne
Next: New Technology Alert: X-Ray-based Ultra-high Density Optical Memory (X-ROM) X-ROM, Inc.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Any EPICS support for ICS 145? Ernest L. Williams Jr.
Next: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" Jeff Hill
