1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
Cc: Till Straumann <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 24 Aug 2006 13:16:01 -0400
Andrew Johnson wrote:
Kate Feng wrote:
Discovery deos not have the necessary capability or connections to the MCP. I was told that
on the boards which use a Discovery system controller, the MCP signal is connected to a
pull-up and therefore not used as it is on other boards. That's the design on the
MVME5500 and MVME6100 boards. I do not see it as a big problem for the
MVME5500 board because ......
Till Straumann wrote :
(currently, a PCI error such as target abort is routed to the one
and only EE interrupt of the powerpc).
The MCP, if available, is routed to the EE interrupt as well.
I personally would see it as a problem, because the EE interrupt is maskable. It's not trivial to write an exception handler that can nest properly such that if an interrupt service routine receives a Target- Abort from a PCI device it will immediately halt and abort the ISR rather than continuing on to completion and only then running the Target-Abort interrupt handler. If all you have is an interrupt, your ISRs probably ought to check with the Tempe chip that they're not getting VME bus errors before relying on the data they've just read (at least if the value they read back was all-1s).
Yes, that is why, as what I stated in the previous E-mail, I do'nt worry about the MVME5500 application because it utilizes the Universe chip instead of the Tempe chip. I was concerned about the application which relies on the Tempe chip of the MVME6100. At this point, our application will only need the PCI bus via the PMCs.
For the MVME6100, I am more concerned with the
"making use of the dud all-1's read data in the process"
that Andrew mentioned earlier. I do'nt seem to get the answer from the
http://www.aps.anl.gov/epics/tech-talk/2006/msg00892.php, which was posted by Till.
Is it in the "vmeTsi148ClearVMEBusErrors(&erraddr);" ? How is it programmed?
I'm not sure I understand your question. The "all-1s read data" I was talking about is the data that is returned if you do a programmed read cycle to the VMEbus that ends in a Bus Error.
This read cycle could happen before the ISR and accidentally update
a value. What I meant is that "Can the bus error handler detect that
and reverse the update?" I guess it does not matter because the wrongly
updated value will not get updated to the EPICS save/restore since
the interrupt latency is probably so fast that the operation would have to be
shut down.
If the Bus Error occurs during a DMA operation using one of the DMA controllers in the Tempe chip then the DMA will be stopped immediately instead, since the controller is inside the Tempe and can see the Bus Error status.
Do you mean the Tempe chip has its own DMA? I do'nt have any datasheet regarding the Tempe chip.
Kate
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Korhonen Timo
Next: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
