Subject: |
RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" |
"David Dudley" <[email protected]> |
To: |
Date: |
Thu, 24 Aug 2006 13:07:32 -0500 |
I've got the file rewritten to use the "getifaddrs" function, and it's working great. Ended up being smaller and simpler than the original, as well (probably only because now I understand how it works).
I agree that the original code probably only need some kind of tweak, and I'll look into that when I'm farther along in getting the port actually working properly. But for right now, a quick and dirty fix was just to rewrite the code. I can see that this may create a problem in the future, as this function is a BSD call that doesn't appear to be in Linux (although a google search shows references to redhat's website - probably just talking about what it does), so it won't be portable across OS's that don't meet BSD standards, but FreeBSD, OpenBSD, and NetBSD (along with osBSD/386 and BSD 4.3 and 4.4 variants seem to all have it).
For the moment ... it's doing its job.
Now, on to the next problem. why dbNameToAddr fails even though I can do a dbl and see the data point names. Probably something else simple.
David
>>> "Jeff Hill" <[email protected]> 08/24/06 10:46 AM >>>
David,
Currently we have needed only these two versions.
libCom/osi/os/default/osdNetIntf.c
libCom/osi/os/win32/osdNetIntf.c
Currently all of the UNIX systems have found the default version to be
sufficient after allowing for some small os dependent variations in the
implementation of ifreq_size().
> On NetBSD, this function returns information that is "inconsistent" with
> Linux, I believe.
As I understand it Darwin (MAC OSX) is working fine with the default
osdNetIntf.c but it does need the more advanced implementation of
ifreq_size(). Be careful to have a look at the two variants of ifreq_size()
and make certain that a proper implementation is selected for NetBSD. If
ifreq_size() was wrong you might see complete garbage in the returned
structures.
This is the default:
epics\base\src\libCom\osi\os\alpha\osdSock.h(70):
#define ifreq_size(pifreq) (sizeof(pifreq->ifr_name))
Here is Darwin (probably the closest relative of NetBSD supported so far):
epics\base\src\libCom\osi\os\Darwin\osdSock.h(80):
#define ifreq_size(pifreq) ((pifreq)->ifr_addr.sa_len +
sizeof((pifreq)->ifr_name))
Linux:
epics\base\src\libCom\osi\os\Linux\osdSock.h(93):
Nevertheless, the source is organized so that you could easily provide an
osdNetIntf.c override in libCom/osi/os/NetBSD based on getifaddrs should
that prove to be necessary.
An implementation based on getifaddrs might be useful but perhaps not yet a
portability bullet as it is not in, for example, my latest vxWorks at hand
(vxWorks 5.4) nor in http://www.opengroup.org/pubs/online/7908799/.
Jeff
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
<2006>
2025
2026
RE: ezca and ENUM Mark Rivers
NetBSD: looks like it running properly. Now for a Display Manager David Dudley
<2006>
2025
2026
