1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NetBSD Port
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Thu, 31 Aug 2006 17:11:48 -0500
David Dudley wrote:
After a quick revision, I'm closer to operation. I can now get the data through the net from the NetBSD machine to the Linux machine if I do "EPICS_CA_ADDR_LIST=10.145.5.38 ./camonitor fred".
I can start the example program or the excas program on the NetBSD
machine, and do "EPICS_CA_ADDR_LIST=10.145.5.38 ./StripTool" on the
Linux machine and see the data now.   It's getting better!  Is it
normal to have to specify the addresses in a list like that, or will
the problem go away when I move the NetBSD machine inside our
firewall?
If your machines are on the same subnet with the same subnetmask and without a firewall they should connect up without your having to set EPICS_CA_ADDR_LIST. By default Channel Access uses both TCP and UDP traffic on ports 5064 and 5065, so if you have a firewall between them you need to open up those ports. However that won't be sufficient if you start running multiple CA servers on the machine inside the firewall (at that point you'll have to turn off the firewall because the second server will bind to a random TCP socket number).
It is possible to use CA across subnets, but you have to understand how it works and configure things properly - see the Channel Access reference manual for all the details if/when you need to do that.
I have a version of StripTool, alh, medm, and probe that all seem to
work OK on the NetBSD machine, but right now I can't access data on
the Linux machine because the NetBSD machine is currently connected
outside the firewall that protects the Linux machine.  I'll move the
NetBSD machine inside the firewall tomorrow and do more testing.
It sounds like the firewall is the source of your problem at this point.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: NetBSD Port David Dudley
Prev: Re: NetBSD Port David Dudley
Next: Re: Fedora Core 6 to drop OpenMotif Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Setting option flags for building system libraries David Dudley
