1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OSI Replacement for rebootHookAdd ???
To: Eric Bjorklund <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 1 Sep 2006 09:00:11 -0500
On Aug 31, 2006, at 5:37 PM, Eric Bjorklund wrote:
Greetings all.
A number of my drivers (and others as well) call the vxWorks routine "rebootHookAdd" -- mostly to install rundown routines that will disable the card's interrupts in the event of a soft reboot. Since I seem to be into portability these days, it would be nice to have an OSI equivalent function.
epicsAtExit seems to be the logical candidate, and there is even a hook in the vxWorks part of libCom/osi/os (atReboot.cpp) that will invoke epicsExitCallAtExits() during a soft reboot. The catch, however, is that you need to have (as I understand it) a routine called "sysAtReboot" built into your BSP for the exit handler to be called on a soft reboot. sysAtReboot (again, as I understand it) is an APS BSP extension that solves the problem of rebootHooks not invoking its exit handlers in the correct order.
So, with the above history out of the way (and feel free to comment on the authenticity of the above), my (perhaps) naive questions are:
1. How does RTEMS solve the soft reboot handler problem (I don't see any similar hook in libCom/osi/os/RTEMS)?
The RTEMS EPICS startup code calls epicsExit when the interactive iocsh completes and the call to main() returns. Have a look at the last few lines of src/RTEMS/base/rtems_init.c.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
OSI Replacement for rebootHookAdd ??? Eric Bjorklund
Prev: Re: Fedora Core 6 to drop OpenMotif Pete R. Jemian
Next: Re: Fedora Core 6 to drop OpenMotif Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: OSI Replacement for rebootHookAdd ??? Eric Bjorklund
Next: Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
