1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Equipment Availability
To: <[email protected]>
Date: Tue, 05 Sep 2006 15:11:20 -0500
Yes, that's what I have been finding.  I know where to go if I want to capture mega-samples per second or more.  Most industrial applications, even those involving turbine control or boiler control don't require sampling like that.  A few hundred per second or so.... more than enough.  In the Water and Natural Gas systems that I work with, nothing happens 'extremely fast'.  Most of the PLCs I work with do input scanning in the tens of milliseconds per channel.
David Dudley
>>> "Dalesio, Leo `Bob`" <[email protected]> 09/05/06 3:05 PM >>>
It would be best to write the drivers for the Siemans PLCs first - then you can add in the IOCs to talk to them and not worry about your plant wiring and IO. Once that is demonstrated, you can start a pilot project to replace a little IO and see what you think. The IO from Hytec is probably the closest to industrial. Most VME is what I would call scientific IO - fast, high precision, low latency response.
-----Original Message-----
Sent: Tuesday, September 05, 2006 12:58 PM
To: [email protected]
Most of what I'm looking to update / replace are Siemens 505 PLC systems.  I'm told I can create an executable program in 'C' or another language, that I can download into the device, but I don't have any documentation on that capability yet.  Unfortunately, these things use a specialized Ethernet card that isn't directly addressable.  I'm hoping to convert these things into a IOC directly, either using another Ethernet card, or using a PPP connection through one of the serial ports.  The chassis holds VME sized cards, and uses the standard VME P1 connector bus, but I don't believe i'm going to be as lucky as being able to just put a VME processor card into them (I wish!).
I spent 3 or 4 days looking for I/O cards for VME or compactPCI, and have discovered that there are very few industrial I/O cards offered.  Industrial cards are usually optically isolated, and directly handle 110VAC on inputs and outputs, and the analogs all handle 4-10ma current loops without converters.  You can use a simple resistor for converting an input (technically considered a 'kludge' by most in industrial working circles), but analog outputs generally take special adapters to convert from voltage to current.
You can't normally run voltage I/O for hundreds of feet without interference from other signals in an industrial plant, but you usually can with current loops.
David Dudley
>>> "Dalesio, Leo `Bob`" <[email protected]> 09/05/06 2:15 PM
You don't need to use VME though - you could just as well talk to PLCs from your Linux or Windows box. What kind of I/O do you have sitting around? We do a lot of RS232, GPIB, OPC, and many PLC manufacturers. Unfortunately, the web page is woefully underdeveloped for the IO that is supported.
Bob
Sent: Tuesday, September 05, 2006 11:51 AM
To: David Dudley
Cc: [email protected]
Subject: Re: Equipment Availability
On Tue, 5 Sep 2006, David Dudley wrote:
> who makes the chassis and backplane?
There are a large number of manufacturers, covering a large price range.
Take a look at VITA or the ads in VMEbus Systems magazine. Here are two I am familiar with:
	http://tracewellsystems.com/
	http://www.wiener-d.com/
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: RE: Equipment Availability David Dudley
Next: RE: Equipment Availability David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
