1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fedora Core 6 to drop OpenMotif
To: <[email protected]>
Date: Wed, 6 Sep 2006 10:03:59 +0100
Just my £0.02 worth of thoughts on the topic of Qt/EPICS GUI...
Is this new Qt version of EDM a re-implementation of EDM, using Qt or is it a new set of CA-aware Qt widgets to use with Qt's fantastic "designer"?
I do favour the idea of taking advantage of the existing designer application from Trolltech and _just_ create a set of CA aware widgets (inherit most parts from the existing Qt widgets).
If done carefully, the designer can be used in almost the same simple way as EDM: you dump your widgets on a form, set the PV properties, compile and run. There should be no need to get into the C++ code - but the option is there if special requirements exists...
If a Python interface is then made for the Qt/CA widgets, even the compilation step can be taken out of the process...
About compatibility with EDM: the output format from designer is an XML description of the GUI. It should be possible to write a script that can parse the EDM/MEDM files and output a similar XML format which can be used by Qt/designer.
Cheers,
Ulrik
  Ulrik Pedersen               phone: +44(0)1235-778580
  Software Engineer            email: [email protected]
      Diamond Light Source Ltd.
      Rutherford Appleton Laboratory,
      Chilton, Didcot
      OxfordShire OX11 0DE
Re: Fedora Core 6 to drop OpenMotif Ernest L. Williams Jr.
Prev: Re: Device with INP as a PV_LINK Tim Mooney
Next: A question concerning rset->special() Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fedora Core 6 to drop OpenMotif Benjamin Franksen
Next: EPICS in VMEbus Systems magazine! Lawrence T. Hoff
