1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Device with INP as a PV_LINK
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Wed, 06 Sep 2006 02:25:03 -0500
Emmanuel Mayssat wrote:
Hello,
I would like to create a stringin PV that takes an aiRecord and format
it. For example, ai could be the number of clock ticks, while the
stringIn is the formatted date.
1/ I want a simple solution with standard records
2/ I need to link the stringin to the ai
I immediately thought that putting the ai in the inp field and declaring
the device as device(stringin, PV_LINK, <dsetCode>,
<dsetStringIdentifier>) would do the trick.
But dbGetLink(psi->inp,..., &localVariable, ..., DBF_DOUBLE,...,0,0) (or
something like that) complains that inp has an invalid type.
How can I link the stringin to the ai correctly ?
Make sure you're passing a pointer to the link field:
dbGetLink(&psi->inp, DBR_DOUBLE, &localDoubleVariable,0,0)
By the way, you example problem is treated in Ned Arnold's devTimeOfDay.c.
I snuck a copy of this into the synApps std module, if you're interested.
For the general problem, the simplest solution I can think of is the sCalcout
record (in the synApps calc module), because you don't have to write device
support to do what you're describing.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: Device with INP as a PV_LINK Andrew Johnson
Device with INP as a PV_LINK Emmanuel Mayssat
Prev: StripTool2_5_10_0 display of waveform records? Jon Brinkmann
Next: RE: Fedora Core 6 to drop OpenMotif Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Device with INP as a PV_LINK Emmanuel Mayssat
Next: Re: Device with INP as a PV_LINK Andrew Johnson
