1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS source Documentation
To: <[email protected]>
Date: Fri, 08 Sep 2006 11:20:59 -0500
Just a strange question, but I've noticed a tendency of all the source files to not have any comments (or very few) in them regarding what they do.
Is this a standard I've just never known about?
Typically, source(s) that I compose end up having as much in comments (or more) than in code, for the simple reason that I can't concentrate on one component at a time, and I might work some now, and some two or three days from now (and I've slept between then and now).
I get so busy with the multiple things I have to do, that if I don't comment the hell out of what I write, I might have to spend quite a bit of time decoding what I was doing before I needed to switch.
Is this the normal style for EPICS, or would there be any objections to comments being added to some of the files as I work with/on them?
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: EPICS source Documentation Kay-Uwe Kasemir
RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Dalesio, Leo `Bob`
Re: EPICS source Documentation Andrew Johnson
Re: EPICS source Documentation Paul Joireman
Prev: Re: Build failure under QNX 6.1 David Eisert
Next: Re: Build failure under QNX 6.1 David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Looking for an IOC for Wiener PL512 Bertrand H.J. Biritz
Next: Re: EPICS source Documentation Kay-Uwe Kasemir
