1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failure under QNX 6.1
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 08 Sep 2006 11:19:39 -0500
Andrew Johnson wrote:
Hi David,
Welcome to the EPICS community.
Hello Andrew,
Thank you. But actually I am on more of an unauthorized feasibility study. We get nagged by visitors from other facilities asking us "Where's the EPICS?". This is especially disturbing when it comes from members of review committees. I have somewhat of an uphill battle if I actually propose joining the EPICS community. If I can get base to build I may start another thread for help on this.
You're going to have to port EPICS to QNX then, since we don't have the operating system interface for that OS in Base.
I was able to figure that out from the EPICS web site. Great job on documentation and training materials by the way.
The part of the error message I'm interested in is this:
make[3]: *** [fdmgr.o] Error 1
make[3]: Leaving directory `/home/Epics/base-3.14.8.2/src/libCom/O.linux-x86'
This tells me that the build failed while it was trying to compile code that will run on Linux, not code that will run on QNX (which would have been an error from inside some libCom/O.qnx-XXX directory). The EPICS build system was designed to compile multiple architectures simultaneously alongside themselves, ...
I left out a bit too much information in my first post. QNX can be built from either a cross development system or native. In its most minimum configuration it can be flashed into a small SBC with only a MB or two. The full configuration requires more than a GB of hard disk space and will run X and larger open source packages like Eclipse, Qt and MySQL. I am running QNX as a native development system on a VME VMIC-7750 CPU board (733Mhz PIII /w 64MB RAM). Our IOCs are diskless but boot off a 64 MB Compact Flash card. The parts of QNX that I need fill about half of the card. My development system is identical except that I have a small hard drive with a complete install of QNX. So from the EPICS build prospective it is almost identical to the Linux build environment. I have hijacked the Linux build scripts rather than potentially causing myself problems by creating a separate QNX build configuration for EPICS base. I realize I am editing files that I should not be editing but I am taking notes and if I can get EPICS to build I will untar a new copy of base and add proper QNX build configuration files. So everywhere you see O.linux-x86 just think O.qnx-x86. All of the code is being built to run under only one architecture.
PS: I have commented out the build of the code in the libCom/fdmgr directory. QNX complies the rest of libCom without error messages. It then proceeds to ToolComms and builds Flex and antelope with out error messages but bombs with a segmentation violation when it runs antelope. I am hoping that this is due to not being able to build the fdmgr code and not a new problem since antelope is being linked to libCom.
While I am waiting for feedback I am assembling the parts to run a newer version of QNX. The newer 6.3 version has gcc 3.3.5.
Please post the output from the following command:
/usr/bin/g++ --version
This should *not* be your QNX cross-compiler, it must be the compiler for the host Linux operating system. What Linux distribution are you building this on?
- Andrew
QNXDevel> /usr/bin/g++ --version 2.95.2
As mentioned above I am not running any copy of Linux. I have built base on a completely separate system running Fedora Core 5. But that is totally unrelated to this problem. Just an FYI that I have been able to build a working copy of base.
A bit of facility background
The facility is the Aladdin synchrotron storage ring in Madison, Wisconsin (SRC). We have about 20 IOCs with approximately 1000 physical control elements (our term is devices, yours is non-virtual PVs). Half of our IOCs are running PIII VMIC-7750 under QNX and the other half are running SBS VIPC-360 VME MC68360 using u/cos. The VIPC-360 are built into our dipole and quadrupole power supplies and have only a small portion of the total PVs. Our Consoles are Windows XP PCs so we do not have much experience with Unix systems. We used to be VAX/VMS based and we switched to Windows about ten years ago. The control system has all the major elements of EPICS but a lot fewer features. This control system has basically been my personal project for more than 20 years.
Dave
Build failure under QNX 6.1 David Eisert
Re: Build failure under QNX 6.1 Andrew Johnson
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: EPICS source Documentation David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build failure under QNX 6.1 Andrew Johnson
Next: Re: Build failure under QNX 6.1 David Dudley
