1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "Best Pratice" on Monitors
To: Tech-Talk <[email protected]>
Date: Fri, 08 Sep 2006 12:10:35 -0500
Hi all,
    So I've just about finished a new device support and record set
involved in my current project, and I am sitting looking at the how to
handle when to raise monitors.
    The IOC dev guide says that record support should *NOT* call
db_post_event() for values that do not change. So I've started coding in
the check for each value held by the record, and I stooped, probably
because its Friday, and looked at why.....
    The record and its connected device have over 100 monitorable
fields, and if any one changes, there will be changes in almost 80 other
fields, so to the point...
    Will I break anything by posting a monitor for the 20 or so
remaining field that have not changed ?
    I will of course incur the network load for 20 extra fields, but
what other costs are there. Or is posting on a no change just bad enough
practice that it should not be done for any reason ?
--Bill
Bill Nolan
Washington University Medical School
Department of Biochemistry
4566 Scott Ave.
Mail Stop 8231
St. Louis, Mo 63110
1.314.362.4445 Fax 1.314.362.7183
Re: "Best Pratice" on Monitors Tim Mooney
Prev: Re: EPICS source Documentation Andrew Johnson
Next: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Gurd, Pamela A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: "Best Pratice" on Monitors Tim Mooney
