1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
To: Till Straumann <[email protected]>
Cc: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 08 Sep 2006 13:36:21 -0400
Till Straumann wrote:
Finally, IMHO it is not *that* big of an issue. If we use an interrupt
to signal bus-errors, as you point out, it might be delivered asynchronously
[as it would anyways as soon as posted transactions are involved]
and therefore harder to debug but you still get a notification that something
is wrong.
Yes, it is not a big issue to use an interrupt to signal bus-errors.
The concern for the Tsi148 is that:
If the transaction was a VMEbus read,
the VME Master completes the Linkage Module command by
filling the buffer with a data pattern of all ones.
It is even possible [for coupled transactions] to suspend the
faulty thread and halt the system if it happens in an ISR.
Can you verify what you meant  "possible"?  Does it happen
automatically without extra coding for sure ?  Do you
mean "nested interrupt" ?  Since nested interrupt is hard
to implement as what Andrew pointed out.  If the bus error
happened in an ISR for a VME read, the read data is not
valid any more, which could, if not checked,  lead to unwanted
VME writes on valid addresses by the following code in the ISR
because the write buffer is flushed only for posted writes that is up
to where the bus error is.
Kate
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Till Straumann
Prev: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Gurd, Pamela A.
Next: Re: "Best Pratice" on Monitors Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Till Straumann
Next: RE: VME Bus Error handling on MVME3100 and MVME6100 boards Thompson, David H.
