1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
To: Andrew Johnson <[email protected]>, [email protected]
Date: Wed, 13 Sep 2006 09:51:30 -0400
Kate Feng wrote:
> Kate Feng wrote:
> > Andrew Johnson wrote:
> > > The PCIbus Retry and Disconnect cycle terminations that you discussed do
> > > not actually stop the data transfer cycle completely, they only permit
> > > it to be run again or to take longer to complete than a regular PCIbus
> > > single I/O cycle.
> > Yes, that's why the overhead is only needed for ISR and where interrupt is
> > disabled.
> I do'nt have the mvme6100 system setup for tests.   However, this is somthing
> that could be verified via some tests.
I really meant that I can not be responsible for  statement that I did'nt
have tests on.   Andrew's  "sure-fire way" could be right.
Kate
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Prev: Failure to build EPICS 3.14.8.2 on Windows XP using VC++ 2005 Express Edition Alan Greer
Next: RE: Failure to build EPICS 3.14.8.2 on Windows XP using VC++ 2005Express Edition Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Till Straumann
