1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Alarm trigger for persistent values?
To: [email protected]
Date: Thu, 21 Sep 2006 09:21:45 +0200
At our infrastructure monitoring system we have the case that
some temperature values should trigger an alarm only if they
remain above/below a threshold (HIHI/LOLO) for longer than a
defined amount of time.
As we could not find support for this feature in the documentation,
we would be glad to receive a suggestion regarding a solution or
implementation we could go for.
The involved sensor devices are represented by "ai" records
with a home-made device implementation. We use EPICS release
3.14 on Linux.
Many thanks in advance!
Bernhard.
RE: Alarm trigger for persistent values? Owens, PH (Peter)
Re: Alarm trigger for persistent values? Ralph Lange
Prev: ICS-130 digitizer EPICS support? Steve Lewis
Next: RE: Alarm trigger for persistent values? Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
