1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ICS-130 digitizer EPICS support?
To: [email protected]
Date: Tue, 19 Sep 2006 10:38:38 -0700
Our requirements have changed slightly :-) Although Ernie Williams sent a complete package of source code for the ICS-145 digitizer, our EE has decided that the ICS-130 more closely meets our needs. Does anyone have EPICS source code for it? Of course, any experience from the field is most welcome.
The ICS-130 and -145 are very similar, with only slight differences in register layout, however, before converting the -145 to -130, I thought I would see if someone has already done it. We will be acquiring the vxWorks source code from ICS, so that should cover the low-level, non-EPICS routines.
We are also purchasing the companion ICS-121 signal conditioning board. Any support for or experience with it?
Thanks.
______________________________________________________________
Stephen A. Lewis                        |
Linac Coherent Light Source             | [email protected]
Lawrence Livermore National Laboratory  | Tel: 925.423.4751
7000 East Ave, L-210                    | FAX: 925.423.1488
Livermore, CA 94550                     |
Prev: Re: RE: Channel archiver r_ani
Next: Alarm trigger for persistent values? Bernhard Lopez
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
