1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics 3.14.8.2 for Windows still has problems
Cc: Ralph Lange <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Tue, 26 Sep 2006 17:20:41 -0400
Andrew,
"perl /epics/base/bin/win32-x86/makeBaseApp.pl -t example example"
doesn't work. (It is not *unix.) I also tried perl -V. Please, look
attachment.
When I did
>set EPICS_MBA_TEMPLATE_TOP=c:/epics/base/template/makeBaseApp/top
Then
C:\testioc>perl ../epics/base/bin/win32-x86/makeBaseApp.pl -t example
example
began to work.
Andrei.
-----Original Message-----
Sent: Tuesday, September 26, 2006 4:42 PM
To: Liyu, Andrei
Cc: Ralph Lange; EPICS-tech-talk
Subject: Re: Epics 3.14.8.2 for Windows still has problems
Liyu, Andrei wrote:
> C:\testioc>perl c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example
> example
> Can't find EPICS base
> C:\testioc>perl epics\base\bin\win32-x86\makeBaseApp.pl -t example
> example
> Can't open perl script "epics\base\bin\win32-x86\makeBaseApp.pl": No
> such file or directory
> C:\testioc>perl ..\epics\base\bin\win32-x86\makeBaseApp.pl -t example
> example
I think it's getting confused by the back-slashes, because in both of
the following examples ...
> example
> Can't find template top directory
> C:\testioc>perl c:/epics/base/bin/win32-x86/makeBaseApp.pl -t example
> example
... it at least succeeded in finding EPICS Base - the error message is
different, and the later errors only occur if it did find Base properly.
I think you should try
i.e. no c: or ..s, just an absolute path on the current drive using
forward slashes.  Oh, and make sure that you don't have a
C:\testioc\configure directory, since the contents of a RELEASE file
will override the command line.  I'm also assuming that you haven't
tried setting the %EPICS_MBA_TEMPLATE_TOP% environment variable since
that will also change things.
If the above doesn't work, please also post the output from 'perl -V'
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
C:\testioc>perl epics/base/bin/win32-x86/makeBaseApp.pl -t example example
Can't open perl script "epics/base/bin/win32-x86/makeBaseApp.pl": No such file o
r directory
C:\testioc>perl -V epics/base/bin/win32-x86/makeBaseApp.pl -t example example
Summary of my perl5 (revision 5 version 8 subversion 8) configuration:
  Platform:
    osname=MSWin32, osvers=5.0, archname=MSWin32-x86-multi-thread
    uname=''
    config_args='undef'
    hint=recommended, useposix=true, d_sigaction=undef
    usethreads=define use5005threads=undef useithreads=define usemultiplicity=de
fine
    useperlio=define d_sfio=undef uselargefiles=define usesocks=undef
    use64bitint=undef use64bitall=undef uselongdouble=undef
    usemymalloc=n, bincompat5005=undef
  Compiler:
    cc='cl', ccflags ='-nologo -GF -W3 -MD -Zi -DNDEBUG -O1 -DWIN32 -D_CONSOLE -
DNO_STRICT -DHAVE_DES_FCRYPT -DNO_HASH_SEED -DUSE_SITECUSTOMIZE -DPERL_IMPLICIT_
CONTEXT -DPERL_IMPLICIT_SYS -DUSE_PERLIO -DPERL_MSVCRT_READFIX',
    optimize='-MD -Zi -DNDEBUG -O1',
    cppflags='-DWIN32'
    ccversion='12.00.8804', gccversion='', gccosandvers=''
    intsize=4, longsize=4, ptrsize=4, doublesize=8, byteorder=1234
    d_longlong=undef, longlongsize=8, d_longdbl=define, longdblsize=10
    ivtype='long', ivsize=4, nvtype='double', nvsize=8, Off_t='__int64', lseeksi
ze=8
    alignbytes=8, prototype=define
  Linker and Libraries:
    ld='link', ldflags ='-nologo -nodefaultlib -debug -opt:ref,icf  -libpath:"c:
\Perl\lib\CORE"  -machine:x86'
    libpth=\lib
    libs=  oldnames.lib kernel32.lib user32.lib gdi32.lib winspool.lib  comdlg32
.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib  netapi32.lib uuid.lib ws2_
32.lib mpr.lib winmm.lib  version.lib odbc32.lib odbccp32.lib msvcrt.lib
    perllibs=  oldnames.lib kernel32.lib user32.lib gdi32.lib winspool.lib  comd
lg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib  netapi32.lib uuid.lib
ws2_32.lib mpr.lib winmm.lib  version.lib odbc32.lib odbccp32.lib msvcrt.lib
    libc=msvcrt.lib, so=dll, useshrplib=yes, libperl=perl58.lib
    gnulibc_version=''
  Dynamic Linking:
    dlsrc=dl_win32.xs, dlext=dll, d_dlsymun=undef, ccdlflags=' '
    cccdlflags=' ', lddlflags='-dll -nologo -nodefaultlib -debug -opt:ref,icf  -
libpath:"c:\Perl\lib\CORE"  -machine:x86'
Characteristics of this binary (from libperl):
  Compile-time options: MULTIPLICITY PERL_IMPLICIT_CONTEXT
                        PERL_IMPLICIT_SYS PERL_MALLOC_WRAP
                        PL_OP_SLAB_ALLOC USE_ITHREADS USE_LARGE_FILES
                        USE_PERLIO USE_SITECUSTOMIZE
  Locally applied patches:
        ActivePerl Build 819 [267479]
        Iin_load_module moved for compatibility with build 806
        PerlEx support in CGI::Carp
        Less verbose ExtUtils::Install and Pod::Find
        Patch for CAN-2005-0448 from Debian with modifications
        Rearrange @INC so that 'site' is searched before 'perl'
        Partly reverted 24733 to preserve binary compatibility
        28671 Define PERL_NO_DEV_RANDOM on Windows
        28376 Add error checks after execing PL_cshname or PL_sh_path
        28305 Pod::Html should not convert "foo" into ``foo''
        27736 Make perl_fini() run with Sun WorkShop compiler
        27619 Bug in Term::ReadKey being triggered by a bug in Term::ReadLine
        27549 Move DynaLoader.o into libperl.so
        27528 win32_pclose() error exit doesn't unlock mutex
        27527 win32_async_check() can loop indefinitely
        27515 ignore directories when searching @INC
        27359 Fix -d:Foo=bar syntax
        27210 Fix quote typo in c2ph
        27203 Allow compiling swigged C++ code
        27200 Make stat() on Windows handle trailing slashes correctly
        27194 Get perl_fini() running on HP-UX again
        27133 Initialise lastparen in the regexp structure
        27034 Avoid "Prototype mismatch" warnings with autouse
        26970 Make Passive mode the default for Net::FTP
        26921 Avoid getprotobyname/number calls in IO::Socket::INET
        26897,26903 Make common IPPROTO_* constants always available
        26670 Make '-s' on the shebang line parse -foo=bar switches
        26536 INSTALLSCRIPT versus INSTALLDIRS
        26379 Fix alarm() for Windows 2003
        26087 Storable 0.1 compatibility
        25861 IO::File performace issue
        25084 long groups entry could cause memory exhaustion
        24699 ICMP_UNREACHABLE handling in Net::Ping
  Built under MSWin32
  Compiled at Aug 29 2006 12:42:41
  @INC:
    c:/Perl/site/lib
    c:/Perl/lib
C:\testioc>
Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
Prev: Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
Next: A question about decoding strings in Asyn.... Dave Reid
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ICS-130 digitizer EPICS support? Steve Lewis
