1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AutoSaveRestore for Windows-based softIOCs
Cc: tech-talk <[email protected]>, Tim Mooney <[email protected]>, "Kasemir, Kay" <[email protected]>, [email protected]
Date: Thu, 21 Sep 2006 22:09:03 -0400
On Thu, 2006-09-21 at 20:45 -0500, Mark Rivers wrote:
> Hi Ernest,
> Those problems have been fixed.  Here are the last few entries in the CVS log.
> RCS file: /net/beams-nfs/export/local/cvs/support/autosave/asApp/src/dbrestore.c,v
> Working file: dbrestore.c
> head: 1.23
> branch:
> locks: strict
> access list:
> symbolic names:
>         synApps_5_2: 1.23
>         R4-2-1: 1.23
>         R4-2: 1.22
>         R4-1-3: 1.22
>         R4-1-2: 1.20
>         synApps_5_1: 1.19
>         R4-1-1: 1.19
>         R4-1: 1.19
>         synApps5-0: 1.8.0.2
>         synApps_5_0: 1.8
>         R2-3: 1.8
>         R2-2: 1.7
>         R2-1: 1.6
>         R1-3: 1.2
>         R3_13_branch: 1.2.0.2
>         R1-2: 1.1.1.1
>         R1-1: 1.1.1.1
>         start: 1.1.1.1
>         std: 1.1.1
> keyword substitution: kv
> total revisions: 25;    selected revisions: 25
> description:
> revision 1.23
> date: 2006/09/07 18:26:19;  author: mooney;  state: Exp;  lines: +22 -16
> Malcolm Walters' patches re errno and myPrintErrno
> revision 1.22
> date: 2006/03/28 22:53:28;  author: mooney;  state: Exp;  lines: +94 -37
> Replaced Debug macros with straight code
> revision 1.21
> date: 2005/12/11 23:26:36;  author: rivers;  state: Exp;  lines: +33 -34
> Changes for WIN32; redefined Debug macro, but I don't like it
> So release R4-2, which is on the synApps Web site, has the required fix.
> http://www.aps.anl.gov/aod/bcda/synApps/autosave/autosave.html
> If you write to Tim he can probably put up the latest release, R4-2-1.  I am using autosave with both cygwin-x86 and win32-x86.
Wow!! That is awesome news. :)
We will inherit these fixes as soon as possible.
Tim, could you let us have Release R4-2-1 as well?
Ernest
> Mark
> ________________________________
> From: Williams Jr, Ernest L. [mailto:[email protected]]
> Sent: Thu 9/21/2006 8:37 PM
> To: tech-talk
> Cc: Tim Mooney; Kasemir, Kay; Williams Jr, Ernest L.
> Subject: AutoSaveRestore for Windows-based softIOCs
> Hi,
> Has anyone managed to get autosave/restore working under Win32?
> Autosave restore does work for linux-based softIOCs.
> Here is the error I get:
> "Installing dbd file ../../../dbd/autosave.dbd"
> cl -c             /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /nologo
>  /D__STDC__=0  /Ox /GL   /W3 /w44355       /MD    -I. -I.. -I..\\..\\..\\include
> \\os\\WIN32 -I..\\..\\..\\include -Ic:\\epicsBase\\R3.14.8.2\\include\\os\\WIN32
>  -Ic:\\epicsBase\\R3.14.8.2\\include        ..\\dbrestore.c
> dbrestore.c
> c:\epicsioc\autosave\autosaveapp\src\save_restore.h(12) : error C2010: '.' : une
> xpected in macro formal parameter list
> ..\dbrestore.c(79) : warning C4273: 'pdbbase' : inconsistent dll linkage
>         c:\epicsbase\r3.14.8.2\include\dbAccessDefs.h(34) : see previous definit
> ion of 'pdbbase'
> ..\dbrestore.c(106) : warning C4244: '=' : conversion from 'double' to 'float',
> possible loss of data
> ..\dbrestore.c(518) : error C2059: syntax error : ')'
> ..\dbrestore.c(543) : error C2059: syntax error : ')'
> ..\dbrestore.c(552) : error C2059: syntax error : ')'
> ..\dbrestore.c(555) : error C2059: syntax error : ')'
> ..\dbrestore.c(558) : error C2059: syntax error : ')'
> ..\dbrestore.c(747) : warning C4018: '<' : signed/unsigned mismatch
> make[3]: *** [dbrestore.obj] Error 2
> make[3]: Leaving directory `C:/epicsIOC/autosave/autosaveApp/src/O.win32-x86'
> make[2]: *** [install.win32-x86] Error 2
> make[2]: Leaving directory `C:/epicsIOC/autosave/autosaveApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `C:/epicsIOC/autosave/autosaveApp'
> make: *** [autosaveApp.install] Error 2
> C:\epicsIOC\autosave>
> The above error refers to lines containing the string Debug (e.g.):
> Debug(10, "ARRAY_BEGIN wasn't found; going to next line of input file\n");
> This appears to conflict with MS C++ and its Debug object, hmm?
> Thanks,
> Ernest L. Williams
AutoSaveRestore for Windows-based softIOCs Williams Jr, Ernest L.
RE: AutoSaveRestore for Windows-based softIOCs Mark Rivers
Prev: RE: AutoSaveRestore for Windows-based softIOCs Mark Rivers
Next: Experience with CAJ Christopher Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
