1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics 3.14.8.2 for Windows still has problems
To: Jeff Hill <[email protected]>
Cc: EPICS-tech-talk <[email protected]>
Date: Mon, 25 Sep 2006 15:25:35 -0400
Ernest Williams found way to work with Windows/CMD(not cygwin)/VC++ 8.0/Epics 3.14.8.2. I have tested with Windows/CMD(not cygwin)/VC++ 7.0/Epics 3.14.8.2.
1. Simple "makeBaseApp.pl -t example example" doesn't work.
2. "makeBaseApp.pl -b <EpicsBase> -t example example" doesn't work.
3. "makeBaseApp.pl -T <EpicsTemplate> -t example example" doesn't work.
But "makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseApp\top -t example example" does work.
Please, fix that.
Thanks, Andrei.
C:\testioc>makeBaseApp.pl -T c:\epics\base\templates\makeBaseApp\top -t example example
Can't find EPICS base
C:\testioc>makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseAp
C:\testioc>dir
 Volume in drive C has no label.
 Volume Serial Number is E886-E139
 Directory of C:\testioc
09/25/2006  03:09 PM    <DIR>          .
09/25/2006  03:09 PM    <DIR>          ..
09/25/2006  03:09 PM    <DIR>          configure
09/25/2006  03:09 PM    <DIR>          exampleApp
09/25/2006  03:09 PM               400 Makefile
               1 File(s)            400 bytes
               4 Dir(s)  22,654,251,008 bytes free
C:\testioc>makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseApp\top -i -t example example
Using target architecture win32-x86 (only one available)
The following applications are available:
    example
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name? example
C:\testioc>
Sent: Monday, September 18, 2006 4:25 PM
To: Liyu, Andrei
Cc: EPICS-tech-talk
Andrei,
I don't appear to be experiencing either of these two problems.
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00323.php
I am using cygwin gnu make 3.80 w/o issues. Is this a problem with a mingw gnu make or is it a problem with using bash to build the system for win32-x86 (on windows I am building using the windows supplied dos shell). On my system mingw does not include a gnu make binary, but I might have an older version of mingw.
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00065.php
I am creating my application (and specifying the path to base) like this, and building the application w/o issues.
>perl ..\base\bin\win32-x86\makeBaseApp.pl -i -t example ex
>perl ..\base\bin\win32-x86\makeBaseApp.pl -t example ex
Is this really an issue with the -b option for makeBaseApp on windows?
Jeff
Sent: Monday, September 18, 2006 1:05 PM
To: EPICS tech-talk
Subject: Epics 3.14.8.2 for Windows still has problems
I have loaded and tried to build Epics 3.14.8.2 on Windows OS with VC++ (VC++ 7.0 in VS2003) and gnu make 3.80.0-3 (mingv).
I found that
- still there is com.dll issue ( http://www.aps.anl.gov/epics/tech-talk/2006/msg00323.php ) - thank you Dale
Then I tried to build test IOC and met the same problem as was noticed here
Usage of "-b <epics_Base>" doesn't help.
Can anyone fix first issue and help with second?
Thanks, Andrei.
RE: Epics 3.14.8.2 for Windows still has problems Ernest L. Williams Jr.
Re: Epics 3.14.8.2 for Windows still has problems Ralph Lange
Prev: Re: Experience with CAJ Thomas Pelaia II
Next: RE: Epics 3.14.8.2 for Windows still has problems Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
