1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer installation
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 6 Oct 2006 16:17:13 -0500
Did you:
a) Create a .dbd file with a registrar command for the sequence program?  For example, I've got an sequencer source file with 'program scanAcqPll' at the top and a scanPll.dbd file containing:
registrar(scanAcqPllRegistrar)
b) Add that .dbd file to your application.  Using my system as an example again, the application Makefile contains the line:
rftest_DBD += scanPll.dbd
  BTW -- my application Makefile also contains:
rftest_SRCS += scanPll.st
  and
rftest_LIBS += seq pv
c) Do a make distclean ; make
On Oct 6, 2006, at 1:41 PM, Emmanuel Mayssat wrote:
Here again, I have to deal with the not-s-straight-forward epics build
system.
So far I always build against the base. I am referring to the
configuration and/or config directories at the top my device source.
In those files the SNC make variable is not set etc.
The sequencer source build correctly but against a local
configuration/config directory.
So far I was able to go from snl to c code and include the c code in my
driver source. But, when I type "help" at the iocsh prompt I do not see
the sequencer commands (such as seqShow, etc).
1/ Where are those commands coming from? A library ?
2/ I include the seq pv seqDev libraries in my ioc. My sequencer.c
program is also added as a SRCS to that same ioc. Everything compile
correctly. But still cannot see the seqShow command in the iocsh help.
What am I not doing correctly ?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: sequencer installation Emmanuel Mayssat
Prev: sequencer installation Emmanuel Mayssat
Next: Re: sequencer installation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
