1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: sequencer installation
To: epics <[email protected]>
Date: Fri, 06 Oct 2006 11:41:02 -0700
Here again, I have to deal with the not-s-straight-forward epics build
system.
So far I always build against the base. I am referring to the
configuration and/or config directories at the top my device source.
In those files the SNC make variable is not set etc.
The sequencer source build correctly but against a local
configuration/config directory.
So far I was able to go from snl to c code and include the c code in my
driver source. But, when I type "help" at the iocsh prompt I do not see
the sequencer commands (such as seqShow, etc).
1/ Where are those commands coming from? A library ?
2/ I include the seq pv seqDev libraries in my ioc. My sequencer.c
program is also added as a SRCS to that same ioc. Everything compile
correctly. But still cannot see the seqShow command in the iocsh help.
What am I not doing correctly ?
Emmanuel Mayssat
Cell: 650/793-0626
Lyncean Technologies, Inc.
"See the invisible"
Re: sequencer installation Eric Norum
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 board Kate Feng
Next: Re: sequencer installation Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
