Zhang,
I'm not sure that the LNK4044 warning is the problem.
However, this line suggests the problem:
cl /nologo /EHsc /GR -c -DPVCA /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0 /Ox /GL
/W3 /w44355 /MD -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I\\base-3.14.8.2\\include\\os\\WIN32
-I\\base-3.14.8.2\\include /Tp ..\\pvCa.cc pvCa.cc
It looks to me like it is looking for EPICS base in the wrong place, i.e. \\base-3.14.8.2, with no dirve specification, rather than something like
C:\EPICS\base-3.14.8.2.
How have you defined EPICS_BASE in seq-2-0-11/configure/RELEASE?
Sent: Fri 10/6/2006 6:33 PM
To: [email protected]
Subject: Failed to install sequencer 2.0.11 on WIN32
I am new to EPCIS and hope to get some help to solve
installation problem.
I am working on winXP Pro with CGWIN (GNUmake 3.81), and Visual
C++ 2005 express as the compiler. I run 'make' in the VC2005 CMD window
because I could not figure out how to do it right in CGWIN. I did get
the EPICS base-3.14.8.2 installed without modifying the file
configure/RULES_BUILD. NO warning or error messages have been found and
the exmaple got compiled and run ok.
However, when I tried to install the sequencer package 2-0-11, I
run into trouble and here is the complete messages (between ***):
C:\CGWIN\usr\local\synApps_5_1_1\support\seq\2-0-11>make
make -C configure install
make[1]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure'
perl /base-3.14.8.2/configure/tools/convertRelease.pl -h win32-x86
checkRelease
perl /base-3.14.8.2/configure/tools/makeMakefile.pl O.win32-x86 ../..
perl /base-3.14.8.2/configure/tools/mkdir.pl O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure/O.win32-x86'
CONFIG_APP_INCLUDE
RULES_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory
make -C src install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src'
make -C pv install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv'
perl /base-3.14.8.2/configure/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv/O.win32-x86'
make[3]: Leaving directory
Installing generic include file ../../../include/pv.h
mkdir ../../../include
Installing generic include file ../../../include/pvAlarm.h
Installing generic include file ../../../include/pvCa.h
-I..\\..\\..\\include -I\\base-3.14.8.2\\include\\o
s\\WIN32 -I\\base-3.14.8.2\\include /Tp ..\\pvNew.cc
pvNew.cc
s\\WIN32 -I\\base-3.14.8.2\\include /Tp ..\\pv.cc
pv.cc
..\pv.cc(247) : warning C4390: ';' : empty controlled statement found;
is this the intent?
..\pv.cc(343) : warning C4390: ';' : empty controlled statement found;
is this the intent?
..\pv.cc(368) : warning C4390: ';' : empty controlled statement found;
is this the intent?
s\\WIN32 -I\\base-3.14.8.2\\include /Tp ..\\pvCa.cc
pvCa.cc
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
/release /implib:pv.lib /out:pv.dll pvNew.o
bj pv.obj pvCa.obj /base-3.14.8.2/lib/win32-x86/ca.lib
/base-3.14.8.2/lib/win32-x86/Com.lib
LINK : warning LNK4044: unrecognized option
'/base-3.14.8.2/lib/win32-x86/ca.lib'; ignored
'/base-3.14.8.2/lib/win32-x86/Com.lib'; ignored
Creating library pv.lib and object pv.exp
pvNew.obj : error LNK2001: unresolved external symbol "public: bool
__thiscall epicsTime::operator<(class epicsTime cons
t &)const " (??MepicsTime@@QBE_NABV0@@Z)
__thiscall epicsTime::operator<=(class epicsTime con
st &)const " (??NepicsTime@@QBE_NABV0@@Z)
pvNew.obj : error LNK2001: unresolved external symbol "public: class
epicsTime __thiscall epicsTime::operator+(double co
nst &)const " (??HepicsTime@@QBE?AV0@ABN@Z)
__thiscall epicsTime::epicsTime(class epicsTime const &)"
(??0epicsTime@@QAE@ABV0@@Z)
__thiscall epicsTime::epicsTime(struct epicsTimeStamp con
st &)" (??0epicsTime@@QAE@ABUepicsTimeStamp@@@Z)
__thiscall epicsTime::epicsTime(struct time_t_wrapper con
st &)" (??0epicsTime@@QAE@ABUtime_t_wrapper@@@Z)
__thiscall epicsTime::epicsTime(struct local_tm_nano_sec
const &)" (??0epicsTime@@QAE@ABUlocal_tm_nano_sec@@@Z)
__thiscall epicsTime::epicsTime(struct timespec const &)"
(??0epicsTime@@QAE@ABUtimespec@@@Z)
__thiscall epicsTime::epicsTime(struct l_fp const &)" (??
0epicsTime@@QAE@ABUl_fp@@@Z)
__thiscall epicsTime::epicsTime(class aitTimeStamp const
&)" (??0epicsTime@@QAE@ABVaitTimeStamp@@@Z)
pvNew.obj : error LNK2001: unresolved external symbol "public: virtual
void __thiscall epicsThreadRunable::show(unsigned
int)const " (?show@epicsThreadRunable@@UBEXI@Z)
__thiscall epicsThreadRunable::~epicsThreadRunabl
e(void)" (??1epicsThreadRunable@@UAE@XZ)
__thiscall epicsEvent::epicsEvent(enum epicsEventInitialS
tate)" (??0epicsEvent@@QAE@W4epicsEventInitialState@@@Z)
pv.obj : error LNK2001: unresolved external symbol _epicsMutexLock@4
pv.obj : error LNK2001: unresolved external symbol _epicsAssert@16
_epicsTimeGetCurrent@4
pv.obj : error LNK2001: unresolved external symbol _epicsMutexUnlock@4
_epicsMutexOsiMustCreate@8
pvCa.obj : error LNK2001: unresolved external symbol
__imp__ca_task_exit@0
__imp__dbr_value_size
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_message@4
__imp__ca_element_count@4
__imp__ca_flush_io@0
__imp__ca_current_context@0
__imp__ca_array_put_callback@24
__imp__ca_search_and_connect@16
__imp__ca_pend_event@8
__imp__ca_attach_context@4
__imp__ca_array_put@16
__imp__ca_add_masked_array_event@52
__imp__dbr_value_offset
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_state@4
__imp__ca_context_create@4
__imp__ca_field_type@4
__imp__ca_clear_event@4
pvCa.obj : error LNK2001: unresolved external symbol __imp__dbr_size
__imp__ca_array_get_callback@20
__imp__ca_array_get@16
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_pend_io@8
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_puser@4
__imp__ca_clear_channel@4
pv.dll : fatal error LNK1120: 41 unresolved externals
make[3]: *** [pv.dll] Error 96
make[2]: *** [install.win32-x86] Error 2
make[1]: *** [pv.install] Error 2
make: *** [src.install] Error 2
It seems to me the key is these two lines--
But I have no idea what led to this.
Here are my settings for PATH, INCLUDE and LIB in winXP.
Path=C:\Program Files\Microsoft Platform SDK for Windows Server 2003
R2\Bin;C:\Program Files\Microsoft Platform SDK for
Windows Server 2003 R2\Bin\WinNT;C:\Program Files\Microsoft Visual
Studio 8\Common7\IDE;C:\Program Files\Microsoft Visua
l Studio 8\VC\BIN;C:\Program Files\Microsoft Visual Studio
8\Common7\Tools;C:\Program Files\Microsoft Visual Studio 8\SD
K\v2.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;C:\Program
Files\Microsoft Visual Studio 8\VC\VCPackages;C:\WIN
DOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program
files\matlab\r2006b\bin;c:\program files\matlab\r2006b\bin\
win32;c:\program
files\ultraedit;c:\cgwin\bin;C:\CGWIN\base-3.14.8.2\bin\win32-x86;
LIB=c:\cgwin\base-3.14.8.2\lib;C:\CGWIN\base-3.14.8.2\lib\win32-x86;C:\P
Server 2003 R2\Lib;C:\Program Files\Microsoft Visual Studio
8\VC\LIB;C:\Program Files\Microsoft Visual Studio 8\SDK\v2.0
\lib;
LIBPATH=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
INCLUDE=C:\CGWIN\base-3.14.8.2\include;C:\CGWIN\base-3.14.8.2\include\os
\WIN32;C:\Program Files\Microsoft Platform SDK f
or Windows Server 2003 R2\Include;C:\Program Files\Microsoft Visual
Studio 8\VC\INCLUDE;
Could you please help on this issue? Any suggestion is welcome.
Thanks and have a nice weekend!
Zhan
Zhan Zhang
Argonne National Laboratory
X-ray Science Division
Bldg 438, D005
9700 S. Cass Ave
Argonne, IL 60439
Tel: (630) 252-0863
Email: [email protected]
- Failed to install sequencer 2.0.11 on WIN32 Zhang, Zhan
RE: sequencer installation Emmanuel Mayssat
RE: Failed to install sequencer 2.0.11 on WIN32 Zhan Zhang
<2006>
2025
2026
<2006>
2025
2026
