1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Failed to install sequencer 2.0.11 on WIN32
To: "Rivers, Mark L." <[email protected]>, <[email protected]>
Date: Sat, 7 Oct 2006 16:00:08 -0500
Mark,
	Thanks for your response!
	Actually, I am quite confused about how to set the path in the
file 'RELEASE' or 'MASTER_RELEASE'.  I tried 'C:\CGWIN\base-3.148.2',
'C:\\CGWIN\\base-3.14.8.2', 'C:/CGWIN/base-3.14.8.2', and
'/base-3.14.8.2'.  I forgot all the details but somehow I decided to
settle with the '/base-3.14.8.2'.  I assumed that is a valid form
because it seems to me paths like '/usr/local' are recognized (I assume
C:\CGWIN is the root).  Is this correct at all?
	I did a quick check on the four different expressions and the
first one (with '\') does not work, but the second '\\' and the third
'/' both ended up with same error message, which is different from what
I got previously--
make -C configure install
make[1]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure'
perl C:\\CGWIN\\base-3.14.8.2/configure/tools/convertRelease.pl -h
win32-x86 checkRelease
perl C:\\CGWIN\\base-3.14.8.2/configure/tools/makeMakefile.pl
O.win32-x86 ../..
perl C:\\CGWIN\\base-3.14.8.2/configure/tools/mkdir.pl O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure/O.win32-x86'
win32-x86 CONFIG_APP_INCLUDE
win32-x86 RULES_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory
make -C src install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src'
make -C pv install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv'
O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv/O.win32-x86'
make[3]: Leaving directory
MakefileInclude:95: *** target pattern contains no `%'.  Stop.
make[2]: *** [install.win32-x86] Error 2
make[1]: *** [pv.install] Error 2
make: *** [src.install] Error 2
	I could not figure out what corresponses to 'MakefileInclude:95:
...'  This might be the reason I opt for '/base-3.14.8.2' format, which
seems carrying on a bit further.
	Any suggestion?
	Thanks!
Zhan
>Zhang,
>I'm not sure that the LNK4044 warning is the problem.
>However, this line suggests the problem:
>cl /nologo /EHsc /GR -c          -DPVCA    /D_CRT_SECURE_NO_DEPRECATE
>/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0  /Ox /GL
>  /W3 /w44355       /MD    -I. -I.. -I..\\..\\..\\include\\os\\WIN32
>-I\\base-3.14.8.2\\include\\os\\WIN32
>-I\\base-3.14.8.2\\include  /Tp ..\\pvCa.cc pvCa.cc
>It looks to me like it is looking for EPICS base in the wrong place,
i.e. \\base-3.14.8.2, with no dirve specification, rather than something
>>like
>C:\EPICS\base-3.14.8.2.
>How have you defined EPICS_BASE in seq-2-0-11/configure/RELEASE?
>Mark
Zhan Zhang
Argonne National Laboratory
X-ray Science Division
Bldg 438, D005
9700 S. Cass Ave
Argonne, IL 60439
Tel: (630) 252-0863
Email: [email protected]
Prev: RE: Failed to install sequencer 2.0.11 on WIN32 Mark Rivers
Next: Re: sequencer installation Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Failed to install sequencer 2.0.11 on WIN32 Mark Rivers
