1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Make error after "makeBaseApp.pl" on win32-x86
To: Epics Questions <[email protected]>
Date: Wed, 11 Oct 2006 11:38:00 +0100 (BST)
Hi All,
I've just compiled EPICS base 3.14.8.2 on Windows XP.
That worked fine.
I've used this batch file to set up my build environment:
set EPICS_HOST_ARCH=WIN32-x86
set HOST_ARCH=WIN32
rem ## Add EPICS to the path
set path=C:\cygwin\home\Andy\epics\base-3.14.8.2\bin\WIN32-x86;%path%
rem ## Add Cygnus GNU win32 to the path
set path=C:\cygwin\bin;C:\cygwin\usr\local\bin;%path%
set MAKE_MODE=unix
call "C:\Program Files\Microsoft Visual Studio 8\VC\bin\vcvars32.bat"
call "C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\SetEnv.cmd"
These settings worked fine to compile base from a DOS commmand line
(i.e. I'm not using the cygwin bash shell).
I then did:
cd "C:\cygwin\home\Andy\ex"
perl c:\cygwin\home\Andy\epics\base-3.14.8.2\bin\win32-x86\makeBaseApp.pl -t example myexample
perl c:\cygwin\home\Andy\epics\base-3.14.8.2\bin\win32-x86\makeBaseApp.pl -i -t example myexample
make
and got:
make -C configure install
make[1]: Entering directory `/home/Andy/ex/configure'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 checkRelease
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/makeMakefile.pl O.WIN32-x86 ../..
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/mkdir.pl O.Common
make -C O.WIN32-x86 -f ../Makefile TOP=../.. T_A=WIN32-x86 install
make[2]: Entering directory `/home/Andy/ex/configure/O.WIN32-x86'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 CONFIG_APP_INCLUDE
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 RULES_INCLUDE
make[2]: Leaving directory `/home/Andy/ex/configure/O.WIN32-x86'
make[1]: Leaving directory `/home/Andy/ex/configure'
make -C myexampleApp install
make[1]: Entering directory `/home/Andy/ex/myexampleApp'
make -C src install
make[2]: Entering directory `/home/Andy/ex/myexampleApp/src'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/makeMakefile.pl O.WIN32-x86 ../../..
make -C O.WIN32-x86 -f ../Makefile TOP=../../.. T_A=WIN32-x86 install
make[3]: Entering directory `/home/Andy/ex/myexampleApp/src/O.WIN32-x86'
make[3]: Leaving directory `/home/Andy/ex/myexampleApp/src/O.WIN32-x86'
MakefileInclude:74: *** multiple target patterns.  Stop.
make[2]: *** [install.WIN32-x86] Error 2
make[2]: Leaving directory `/home/Andy/ex/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/Andy/ex/myexampleApp'
make: *** [myexampleApp.install] Error 2
and lines 63-75 of "MakefileInclude" are:
ifeq ($(filter myexample,$(TESTPROD) $(PROD)),myexample)
ifeq (,$(strip $(myexample_OBJS) $(PRODUCT_OBJS)))
myexample_OBJS+=myexample$(OBJ)
endif
myexample_RESS+=$(addsuffix $(RES),$(basename $(myexample_RCS)))
myexample_OBJSNAME+=$(addsuffix $(OBJ),$(basename $(myexample_OBJS)))
myexample_DEPLIBS=$(foreach lib, $(myexample_LDLIBS),\
 $(firstword $(wildcard $(addsuffix /$(LIB_PREFIX)$(lib).*,\
 $($(lib)_DIR) $(SHRLIB_SEARCH_DIRS)))\
 $(addsuffix /$(LIB_PREFIX)$(lib)$(LIB_SUFFIX),\
 $(firstword $($(lib)_DIR) $(SHRLIB_SEARCH_DIRS))/)))
myexample$(EXE): $(myexample_OBJSNAME) $(myexample_RESS) $(myexample_DEPLIBS)
endif
I'm obviously doing something wrong since no one else is having this
problem! Any help appreciated.
Many thanks!
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
RE: Make error after "makeBaseApp.pl" on win32-x86 Zhan Zhang
Prev: Segment fault for edm 1-11-0m Jianguo DING
Next: Re: Segment fault for edm 1-11-0m Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics driver for SRS RGA100 Mohan Ramanathan
Next: RE: Make error after "makeBaseApp.pl" on win32-x86 Zhan Zhang
