1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: AAI/AAO database information
To: <[email protected]>
Date: Fri, 03 Nov 2006 11:18:00 -0600
I've seen references to AAI and AAO records someplace, which I assume are Array Analog Input and Output.  Is support for that put in the device driver?
I have a condition working with the Multilin control relays, where I need to be able to generate a multiple register output sequence, where the entire sequence is done in a single record.
This would fit that perfectly, I think.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: AAI/AAO database information Andrew Johnson
Prev: RE: Multihomed IOC Jeff Hill
Next: Database hanging Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ant problem when building Irmis Lecorche Eric
Next: Re: AAI/AAO database information Andrew Johnson
